1990 Dodge Ram Power Steering
113,000 MILES • V8 • 4WD • MANUAL
RUSS S
When I turn the steering to the full right or left limits, the power steering pump will seize up just for a moment causing the belt to squeal. If I continue to force the right and left, it will continue to seize up.
I have had the limiters replaced on the steering column to prevent over steering. A new steering pump was put in also and the problem continues.
Any ideas.
Jan 7, 2010 at 12:49 AM
  • 110,248 POSTS
If you are at the limits and try to hold it there or force it further, the pressure builds in the pump and will cause this.
Jan 8, 2010 at 1:21 PM
RUSS S
I replaced the pump thinking a faulty pump was causing the build up in pressure. I am to assume there is some release valve, or pressure valve that is not opening when the pressure reaches the point where the pully seizes?
Jan 15, 2010 at 11:32 PM
