Ok, I take it you have the 5.2L 318 engine. If so you won't find a belt routing diagram. The belt routing diagrams are for Serpentine Belts. The older vehicle that use the V-Belts are pretty simple to figure out.
If there are no belt on it at all, what you need to do is look at the engine and make a diagram of all the pulleys and what they are. Then go to the parts store and have them look up the belts and they can tell you what belts you will need and were they should go.
Mark
Oct 2, 2009 at 11:22 AM
