1990 Dodge Ram
CAYLONTHEDE
  • 1990 DODGE RAM
  • V8
  • 160,000 MILES
The engine looses power under load, back fireing out of the throdel body whe you press down on the gas.
I changed the o2 sensor, tps, map sensor, fuel pressure regulator fule injectore, plugs plug wires cap and rotor fuel pump and strainer
Friday, July 23rd, 2010 AT 4:12 PM
  • 110,071 POSTS
Have you checked to make sure the catalytic converter isn't plugging?
Saturday, July 24th, 2010 AT 12:02 AM
CAYLONTHEDE
Yes and it isn't pluged
Saturday, July 24th, 2010 AT 7:47 AM
  • 110,071 POSTS
Okay. You have replaced just about everything I can think of that could cause this. Have you checked for any vacuum leaks? Is the EGR working properly? Does the check engine light come on?
Saturday, July 24th, 2010 AT 10:32 PM
