1989 Dodge Ram won't turn over
QTMLEAP
Engine Mechanical problem
1989 Dodge Ram V8 Two Wheel Drive Automatic
we have replaced the starter, checked the flywheel and battery. Starter will try to engage but will not turn engine over. tryed to jump the starter wires but got nothing. Flywheel is not missing teeth and the pulley in front will move when the belt is turned manually. What could be wrong??
May 15, 2010 at 10:36 AM
  • 75,988 POSTS
If you can turn the crankshaft manually 720 degs the engine is not seized if not its binding somewhere inside-If its not seized the starter overrunning clutch is slipping or you have an excessive voltage drop.
May 15, 2010 at 10:44 AM
