1988 Dodge Ram
188,000 MILES • V8 • 2WD • AUTOMATIC
GRAGONIOD66
when the truck is idleing it idles up and down has new wires plugs and no check engine light is on and it back fires and the timing is set ferfect no vacume leaks found and it will run fine sometimes
Mar 2, 2009 at 2:17 AM
  • 110,248 POSTS
Hi:
Without the check engine light, this is a tough one. Does the truck still have a catylatic converter? Have you checked to make sure it isn't plugged? Have you checked the throttle position sensor or idle air control valve? Finally, check the egr valve and make sure it isn't carboned up and when it closes, it seals.
Let me know what you find.
Mar 2, 2009 at 2:48 AM
