1987 Dodge Ram oil shooting out of fill cap
DAVIDSTEEL
Engine Mechanical problem
1987 Dodge Ram Two Wheel Drive Automatic
changed pcv vale and now oil is shooting out of cap and dip stick even worse than before
Oct 9, 2010 at 8:40 AM
JDL
  • 16,098 POSTS
Too much crankcase pressure. I worked on a vehicle once that had a hole in the piston, had so much crankcase pressure, it blew the pcv valve out and blew oil all over the engine compartment. You might do a compression test on the cylinders?
Oct 9, 2010 at 9:23 AM
