Engine Mechanical problem
1987 Dodge Ram Two Wheel Drive Automatic
changed pcv vale and now oil is shooting out of cap and dip stick even worse than before
Saturday, October 9th, 2010 AT 3:40 PM
JDL
MECHANIC
Too much crankcase pressure. I worked on a vehicle once that had a hole in the piston, had so much crankcase pressure, it blew the pcv valve out and blew oil all over the engine compartment. You might do a compression test on the cylinders?
