When i first start my tuck, i get alot of black smoke from the exhaust pipe. checked the oil this morning and had a strong smell of gasoline.
Nov 26, 2009 at 3:23 AM
✓Experienced Mechanic
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
