1987 Dodge Ram Loose Door Handle Fix
SMARTSAMMY
vandals pried-loose the driver's side door latch,key still works and the rod which pulls the lock open can be operated by hand,however i would like to re-install the now-loose door handle,or better yet,make it tight to the door as original.(manual window not power).
thanx.
Aug 8, 2007 at 5:42 AM
DPWD23
  • 136 POSTS
You will likely find all the parts you need at a junk yard. Take pictures of how yours is arrainged before taking them apart, and put in the ones from the junk yard door.
Some junk yards may make you buythe whole door, if so find one with broken glass so it's cheaper... you after all, only need the door handle parts.
Aug 10, 2007 at 11:08 AM
Suggested Repair
Source replacement door-handle parts from a junkyard. Photograph the existing linkage arrangement before disassembly, then install the donor parts. If the yard requires buying a whole door, choose one with broken glass to reduce cost since only the handle hardware is needed.
Conversation Summary
The owner of a 1987 Dodge Mini Ram cargo van says vandals pried the driver's door latch loose. The key still works and the lock rod can be operated by hand, but the door handle is loose and needs to be remounted or tightened. The windows are manual. The expert advises obtaining the needed handle parts from a junkyard, photographing the original arrangement first, and transferring the donor parts. If a whole door must be purchased, selecting one with broken glass can reduce the cost.
