1986 Dodge Ram No spark no start
46,000 MILES • 6 CYL • 2WD • AUTOMATIC
KENTLISA15
I have an in line 6 that cranks but will not fire. My alt was overcharging and burn the fuseable link. I replace alt and link no change. PLEASE HELP!
Jun 24, 2010 at 6:11 AM
  • 75,988 POSTS
cranks but will not fire-Do below to determine if its a fuel or spark issue
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 24, 2010 at 9:27 AM
