1986 Dodge Ram
CASHMAN316
1986 Dodge Ram V8 Two Wheel Drive Automatic
well i put gas in the carbater and it still wont run but crank over and if wait about 2 hour if run and then does it again i done repair the cap,plug wire coil and rotoe button
Jul 29, 2010 at 6:02 AM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jul 29, 2010 at 4:14 PM
