1985 Dodge Ram Sluggish and Chokes when accelerating
77,000 MILES • V8 • 2WD • AUTOMATIC
BWYNES
My 1985 Dodge Ram starts up great but when I drive it, it starts to sound like it's choking and acting really sluggish, especially up hills. What can i do to fix it?
Oct 9, 2009 at 8:43 AM
  • 75,988 POSTS
Could be caused by the following:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Oct 9, 2009 at 10:20 AM
