1985 Dodge Ram gears wont stay
FABIAN1
  • 16 POSTS
Transmission problem
1985 Dodge Ram 4 cyl Two Wheel Drive Automatic
Hello: Well my 85 ram 50 trucks transmition wont stay in parking gear, and first and second don´t work as well. I used to use it to haul cement and i recently lost the transmition control. Thank you will be waiting.
Jul 24, 2010 at 8:53 PM
HMAC300
  • 48,601 POSTS
a shift cable may have broken if it has one, bu ttake it to a trans pro, you may have some serious problems there due to the weight you've been hauling.
Jul 25, 2010 at 12:01 PM
FABIAN1
  • 16 POSTS
THANK YOU BUT CAN U PLEASE GIVE ME SOME PICTURES ON THE CABLE OR HAW CAN I CHECK IT OUT?
Jul 25, 2010 at 12:35 PM
HMAC300
  • 48,601 POSTS
there are no pictures available unless you get the correct manual. Best bet is to have a helper and look under and where the cable connects. If you have a console in this then you'll have to take the console out or at least apart to visibly check .
Jul 26, 2010 at 3:06 AM
FABIAN1
  • 16 POSTS
o.k. i will check it out ill let u know later on today thanks by the way God bless you.
Jul 26, 2010 at 3:21 AM
FABIAN1
  • 16 POSTS
well i have the transmition still don´t know but im going to take it to a shop thank you for ur help..
Aug 6, 2010 at 2:27 PM
