1985 Dodge Ram engine noise
10,000 MILES • V8 • 2WD • AUTOMATIC
DWORTHYSR
on the right cylinder the second rocker arm is loose and hits the first one the rest of the rocker arms are tight and do not hit each other. I put somw old leaded gas in the tank and have had this problem ever since. I removed the gas and changed oil but have this problem.
Sep 26, 2009 at 2:03 AM
ANJR
  • 32 POSTS
[quote:7eb6ac070a="dworthysr"]Engine Mechanical problem
1985 Dodge Ram V8 Two Wheel Drive Automatic 100,00 miles
on the right cylinder the second rocker arm is loose and hits the first one the rest of the rocker arms are tight and do not hit each other. I put somw old leaded gas in the tank and have had this problem ever since. I removed the gas and changed oil but have this problem.[/quote:7eb6ac070a]
Do you hear a constant "ticking" noise? Loose rocker arm sounds like a collapsed lifter.
Oct 3, 2009 at 1:28 PM
