1985 dodge ram
RFLLIPS
I own a 1985 Dodge ram d-100 , 2 w/d , 6 cyl. with about 125,000 miles on it. I only use it to get back and forth to work so i'm trying to get one more year out of it. I'm having trouble with my left rear taillight/brake light. Its very dim and when my tail lights are on my brake light doesnt work. The right side is fine.
Sep 24, 2007 at 9:04 AM
BOB Q
  • 11 POSTS
it sounds like you have a ground problem try hooking a jumper wire to the ground side of the or base of the bulb holder and then to a clean metal location. if that changes your brightness then you need to find the connection point of the ground and clean that up. or replace the ground wire
good luck.
Oct 8, 2007 at 11:03 AM
