1982 Dodge Ram starting
108,000 MILES • V12 • FWD • MANUAL
SCARY LARRY
sometimes this truck wont start.the engine turns but i get no spark.i think wires under the steering colum may be causing this problem.its an 82 dodge ram.what commponents under the dash should i check?
Jan 26, 2009 at 3:46 AM
  • 75,988 POSTS
Do you have power to the coil from the ignition switch when its on run position?
Jan 26, 2009 at 3:49 AM
SCARY LARRY
how would i check that?
Jan 26, 2009 at 3:57 AM
  • 75,988 POSTS
Find the coil positive terminal turn key on and check for battery voltage with a voltmeter
Jan 26, 2009 at 8:21 AM
SCARY LARRY
today i tryed to start this truck (82 dodge ram V8)and..... no fire.i jiggeled some wirwes under the dashboard and it fired up. i think my problem is there ....... what should i look for?
Jan 27, 2009 at 8:18 AM
