Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Ram
Engine
Symptoms
Stall While Driving
1977 Dodge Ram problem
1977 DODGE RAM
250,000 MILES • V8 • 4WD • AUTOMATIC
PHILIPSOBERS
MEMBER
1 POST
stalls when put in gear /drive/revers
Nov 28, 2008 at 10:26 PM
Experienced Mechanic
HI:
The first thing to check is the idle. It should be around 1K RPM's in park or neutral and 800 in gear. If that is ok, check for vacuum leaks. Also, does the exhaust smell like the engine is running rich?
Dec 8, 2008 at 11:38 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
