P0340 code
138,000 MILES • 5.7L • V8 • FWD • AUTOMATIC
DODGE2005
I start it and it dies. Check engine light stays on sometimes it blinks. I have put a new fuel pump in, camshaft position sensor, crankshaft position sensor, map sensor, cleaned the throttle body, checked wiring and fuses, and checked the battery and alternator. I cannot figure it out it still dies please help.
Sep 9, 2016 at 11:16 PM
SATURNTECH9
  • 30,868 POSTS
What are the exact code numbers not code descriptions you have ?
Sep 9, 2016 at 11:22 PM
DODGE2005
I only got one code that came up P0340 the camshaft position sensor that is the only code I get.
Sep 9, 2016 at 11:24 PM
SATURNTECH9
  • 30,868 POSTS
If your check engine light is blinking that usually means you have a bad miss fire and there should be miss fire codes for that.
Sep 9, 2016 at 11:45 PM
DODGE2005
No I have had the computer hooked up ten times and it gives me P0340 the odd thing is that it only roughly starts after it sits for awhile. Then it only runs for about five minutes before it dies.
Sep 10, 2016 at 12:09 AM
SATURNTECH9
  • 30,868 POSTS
When it dies will it restart right away or do you have to wait before it will start right up.
Sep 10, 2016 at 1:53 AM
DODGE2005
I have to wait awhile most of the time to get it to start again. Sometimes it will start up again but not without cranking on it for a little.
Sep 10, 2016 at 4:50 AM
SATURNTECH9
  • 30,868 POSTS
Do you have a scan tool that can show the cam sensor data?
Sep 10, 2016 at 11:34 AM
