03 Dodge Ram 1500 4.7
I got a 03 Dodge Ram from a friend . The truck never started, the orginal engine was seized up so I got a replacement and swaped it out . I changed the wire harness as a pre-caution . The engine would crank but will not start.I changed cam and crank sensors same results. Got a scan with a OTC scanner done and it does not detect any crank signal or rpm. If a wrench is passed
over the crank sensor the ASD relay would click. Any suggestions would be welcomed
Sep 8, 2007 at 3:18 PM
