1996 Dodge Ram Van Coolant Sensor Light
DODGE
EVREDENB
I have a 1996 dodge rom van full size with an engine light on, when I took it and had it put on a computer, it said that it had a bad coolant sensor. It is a 6 cylinder, automatic with 150,000 miles.
The part store gave me the wrong sensor, so i brought both in and got the correct one, but the light is still on.
Since the part store gave me the wrong one at first, i'm second guessing my self, as to if I changed the correct one.
If you could e-mail me any info I would appreciate it. Also if you have a picture of the engine showing the location of the senso that would lso be great.
Thanks
Eileen
Oct 28, 2007 at 11:45 PM
2CARPRO JACK
  • 11,533 POSTS
Is one of the sensors a 1-wire and the other a 2 wire?
if so the 2-wire is the coolant sensor and the 1-wire is the temp gauge sender
Oct 29, 2007 at 3:44 AM
EVREDENB
[quote:080e4bdc03="2CarPro Jack"]Is one of the sensors a 1-wire and the other a 2 wire?
if so the 2-wire is the coolant sensor and the 1-wire is the temp gauge sender[/quote:080e4bdc03]
Thankyou we will try changing the 2 wire sensor. by the way the van is running a little warm, would this sensor cause that as well.
thanks eileen
Nov 14, 2007 at 9:10 PM
2CARPRO JACK
  • 11,533 POSTS
The sender being off a little can make it seem as though it is running warm, same with a gauge that is off a little.
Nov 15, 2007 at 12:03 AM
Suggested Repair
Confirm the engine coolant temperature sensor is the 2-wire unit, not the 1-wire temperature gauge sender, and replace the correct 2-wire sensor if the wrong part was installed. A slightly inaccurate sender or gauge can also make the van appear to run warm.
Conversation Summary
The owner of a 1996 Dodge Ram full-size van with a check engine light was told a scan showed a bad coolant sensor. After installing a replacement, the light remained on, and the owner was unsure whether the correct sensor had been changed. The expert said the 2-wire unit is the coolant sensor and the 1-wire unit is the temperature gauge sender. The owner planned to change the 2-wire sensor and asked whether it could explain the van running slightly warm. The expert said a slightly inaccurate sender or gauge can make it appear warm.
