Dodge Check Engine Light On Steady
DODGE
ROBYNPAY
My engine light is on. the car does not run or sound different. The light is not blinking. I tried tightening the gas cap. Someone said to put water in my antifreeze tank, not sure if that is a good idea. Any suggestions?? Thanks.
Jun 1, 2006 at 1:01 AM
LOSONE
  • 1,616 POSTS
When the light is on it has set a hard code. The light is to notify the driver that there has been a sensor failure. If the vehice is running OK then it is probably an emission failure.
Take it to a shop and have somebody read the code with an engine scannner. THAT'S the only way to tell what the light represents.
Putting water in the coolant jug will do about as much good as going to McDonalds and getting a coke.
Good luck
Jun 1, 2006 at 8:47 AM
ROBYNPAY
[quote:c20d76a3a5="losone"]When the light is on it has set a hard code. The light is to notify the driver that there has been a sensor failure. If the vehice is running OK then it is probably an emission failure.
Good luck[/quote:c20d76a3a5]
Thank you!
Jun 1, 2006 at 1:13 PM
Suggested Repair
Have a shop read the stored diagnostic code with an engine scanner. A steady light with normal running often points to an emissions-related sensor fault; adding water to the coolant will not address the light.
Conversation Summary
The owner reported a steady, non-flashing check engine light on a Dodge that still ran and sounded normal. Tightening the gas cap did not help, and they asked whether adding water to the coolant was appropriate. The expert explained that the light indicates a stored hard code, likely an emissions-related sensor failure if the vehicle runs fine, and said the only way to identify it is a scan. Adding water to the coolant was dismissed as unrelated.
