Cooling Fans Inop
DODGE
CARAMAN
Cooling fans inop when above normal temp.
Fans verified good by connecting directly to battery.
Removed and tested engine coolant temp sensor - at 200 degrees, 800ohms - good
Fuse good
Didn't see a relay
Any ideas?
Feb 15, 2006 at 4:21 AM
PEPPERMRJ
  • 1,158 POSTS
How bout a year , model, engine, and mileage. There be a relay there somewhere my friend.
Post back. :)
Feb 15, 2006 at 8:49 AM
CARAMAN
99 Dodge Caravan, 3.3 liter engine w/ 105k miles
I replaced all 3 relays underneath the dashboard, no change.
I started replacing relays in the PDC in the engine compartment, no change. I also verified the operation of each relay in the PDC by testing its primary function (horn, wipers, fuel pump, etc) and they all work. The only thing I can find specifically identifying the radiator fans is a 40-A fuse in the PDC.
The schematic shows a relay between the PCM and the fans, but I can't find it anywhere in the vehicle.
Bought an OBDII reader to look further.
Feb 15, 2006 at 9:53 AM
PEPPERMRJ
  • 1,158 POSTS
I checked my book. It says to test the relay but does not identify its location.
Ley us know what you find.
Feb 15, 2006 at 10:20 AM
LITTLESCHIPPER
I had the same problem on my '92 Grand Caravan. All the relays were fine, I took it to the dealer and it was a blown fusuble link. Check continuity in the wiring.
Apr 6, 2006 at 6:27 AM
