1997 Dodge Surge and Cylinder 5 Misfire
1997 DODGE
THUNDERHORSE
This car surges at any constant speed. Why?
I also have a po305 code, but have changed the plugs and wires. It was gone for two days and then came back. It is a misfire on cylinder #5. Could this be the coil? Some say that I would have a problem on #2 cylinder if the coil was bad.
Help save this Car!
Feb 27, 2006 at 6:29 AM
PEPPERMRJ
  • 1,158 POSTS
A good read http://www.2carpros.com/first_things/car_surges.htm
Can you swap wires or coils and see if the problem follows the coil?
Good luck and let us know. :)
Mar 3, 2006 at 11:13 AM
Suggested Repair
Swap the ignition wires or coils and see whether the cylinder 5 misfire follows the coil. Also review common causes of surging at a constant speed.
Conversation Summary
A 1997 Dodge owner reports surging at any constant speed and a returning P0305 misfire on cylinder 5 after replacing the spark plugs and wires. They ask whether a bad coil could be responsible without also affecting cylinder 2. The expert suggests reviewing surge guidance and swapping wires or coils to see if the problem follows the coil.
