2004 Other Dodge Models HEATING SMELL
2004 DODGE
11,700 MILES • 4 CYL • FWD • AUTOMATIC
RACHEEMBA31
i HAVE A 2004 JEPP LIBERTY THAT HAS BEEN DOING GREAT WITH THE HIGH MILEAGE IT HAS. HOWEVER, THIS WEEK I HAVE BEEN SMELLING A SORT OF BURNT SMELL ONLY WHEN THE HEAT IS RUNNING. wHAT COULD IT BE SO I CAN GET IT REPAIRED?
Jan 2, 2010 at 1:21 AM
HMAC300
  • 48,601 POSTS
if yuo are smelling it while the heat is on then it is either something in your heat duct or a heater core. If you are getting like fog on thewindow or wetness on the window, your coolant should be low. Also look for antifreeze on the passenger side carpet, it will be wet on the tunnel or it will be leaking outside through the a/c drain. You could also have oil leaking on a manifold causing the smell. A mechanic should be able to diaznose it fairly quick..
Jan 6, 2010 at 5:55 AM
