2002 Other Dodge Models van
2002 DODGE
130,000 MILES • V8 • 2WD • AUTOMATIC
MEL MILLER
van keeps on stalling now won't start gauges all went dead odometer if flashing NO BUS
Aug 23, 2009 at 11:32 AM
No start condition do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Aug 23, 2009 at 11:55 AM
MEL MILLER
understand what you are saying put on scanner no codes. fuel pump,cam/crank sensor and coil don;t explain why my gauges went dead.plus the no bus code. i am thinking something electrical. runs great untill dash freaks out.
Aug 23, 2009 at 12:00 PM
What I've suggested was for this: van keeps on stalling now won't start, as for the gauges its defintely an electrical problem. Could be the ignition switch itself
Aug 23, 2009 at 12:47 PM
MEL MILLER
The no start info is good advise but i think the electrical problem is the key with no gauges and odometer flashig no bus. As far as the ignition switch i already changed the electrical box for the ignition because i here they have alot of problems. do you have any more sugestions.please help me. have you ever heard of the no bus thing. my snap-on scanner says to check the iod fuse. but i could not find the location anywhere.I only found a relay marked iod and i changed it with no luck i pulled all fuses under hood and in van all where good.
Aug 23, 2009 at 1:24 PM
