2000 Other Dodge Models Rear Differential Fluid leaking slow
2000 DODGE
220,000 MILES • V8 • 4WD • AUTOMATIC
KCURTIN
I have a 2000 Dodge Cherokee Jeep. The rear differential fluid is slowly leaking. I am unable to get it repaired for at least 2 weeks. The mechanic filled it up. Is it safe to drive in the meantime and how involved is this repair ?
Jul 21, 2008 at 6:52 AM
  • 110,248 POSTS
Hi:
It's safe to drive as long as there is enough gear lube in the differential. If it's loosing it fast, you'll need to keep an eye on it.
As far as cost, I don't know where it's leaking from. Is it the pinion seal, axle seals, or the differential cover?
Oct 10, 2008 at 4:47 PM
