van was working turned of f key,tured on to start,no gages in cluster working tured off and on about every 10 th time gages come on and van runs,took van to dealer ,they had it three days,did tune up replaced catlitic converter,still no run,said might need pcm ,I ran a gauge ck,push trip meter button,10 second turn on key,ck,ok,ran a test while cracking stater,no buss message appered.told dealer ,the said it wasnt important,they un plugged pcm with out removeing neg battery cable pluse the ran battery down so the hooked up battery charger to battery with cables still on battery,they removed the 3 plugs from pcm and hooked to a used pcm not instaled or grounded said nothing wrong with old pcm,the never scaned for codes this is a service van and I need it to work,your help would mean a lot,thanks rob
Dec 15, 2007 at 5:26 AM
