1997 Other Dodge Models fuel injectors sticking open
1997 DODGE
212,000 MILES • V8 • 2WD • AUTOMATIC
MCSMACK
It has coded out the throttle body sensor which was replaced along with coolant temp sensor and manifold air intake sensor. Problem has gotten steadily worse with 2 injectors hanging open when it happens
Jul 29, 2008 at 12:59 AM
  • 110,248 POSTS
Hi:
If the fuell pressure falls within spec, replace the injectors. The popit valve is most likely worn.
Mar 14, 2009 at 11:07 AM
