1996 Other Dodge Models Ignition Coil
1996 DODGE
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
MDLRJACOBS
My 1996 D Ram Van is showing codes 351 and 300. I believe 351 is the ignition coil. The vehicle is really misfiring, almost like it's out of gas. Is the ignition coil something that can be easily replace? I believe that I should also replace all plugs and plug wires but wanted to make sure coil can be replaced faily easily.
Oct 20, 2008 at 7:36 AM
  • 110,248 POSTS
You shouldn't have any trouble replacing the coil. It bolts on and there is just a electrical plug to remove.
Dec 2, 2008 at 8:46 AM
