1994 Other Dodge Models wont start
1994 DODGE
148,000 MILES • V8 • 4WD • AUTOMATIC
GYPSYDMEN
the van started last night with no problem. before we got home it sputtered and then stalled out. After that we were unable to get it to turn over again.
Oct 11, 2010 at 3:02 PM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Oct 11, 2010 at 9:14 PM
