1994 Other Dodge Models hard to start
1994 DODGE
127,000 MILES • V8 • 2WD • AUTOMATIC
LION78
hi i have a 1994 dodge ram van 350 5.9 and the problem that im having is that whenever i start up cold the van starts up one crank but when it begin to getup to normal temperture or i try to take off the van shuts off and wont start anymore until its cool and its kicks over one crank.i have changed coolant temperture sensor,map sensor,ignition coil,plug wires,plugs,distributer cap and roter
Dec 9, 2009 at 3:38 PM
HMAC300
  • 48,601 POSTS
check your pickup coil in the distributor forresistance. It may be to high and causing this. Also check your coil for resistance. scan your engine for any codes as well . Replace your fuel filter as well.
Feb 13, 2010 at 1:15 AM
