1993 dodge 250 4x4 starts when cold,dies when warm.
1993 DODGE
DAVE 1
I have a 1993 dodge ram 250 4x4,360, AT,113,000 on the miles. no check engine lite. starts fine cold, warms up starts to misfire and will die.will start if starting fluid is used but will only run at higher rpm,s will not start again until it cools down.
Oct 20, 2007 at 1:40 AM
BLACKOP555
  • 10,386 POSTS
sounds like MAF may need to be cleaned causing the engine not to mix fuel properly also the coolant temp sending unit may be a tad off.
Oct 20, 2007 at 2:38 AM
