1992 Other Dodge Models Battery Drainage
1992 DODGE
15,000 MILES • 6 CYL • FWD • AUTOMATIC
KAYLAS13
My 1992 Dodge B250 Van is constantly going dead. I have tested the alternator and the battery itself and both test good. I have started checking the fuses with a volt meter. Discovered that my fuse for hazard lights was pulling juice. Could this be the cause of my battery going dead overnight?
Jul 22, 2008 at 4:26 AM
  • 110,248 POSTS
Hi:
Yes, anything like that could cause the battery to go bad. Pull the fuse overnight and see if it's ok in the morning.
When the alt was tested, were the diodes tested too, or did the only check output?
Oct 10, 2008 at 4:40 PM
