I can't find the voltage regulator?
1991 DODGE
156,800 MILES • V8 • 2WD • AUTOMATIC
PONCHOOO
I like to know the way that looks the SMEC on my 1991 dodge van 250 with a 360 engine and the location too I have a new battery and a good alternator and I can't find the voltage regulator in the fire wall and is not internal(alternator) reading the manual book they appoint to a regulator located in the SMEC Ihave an idea of what looks like but I want to make sure(Located in center of fire wall above engine and looks like black hard plastic box? )
thank you very much David
Dec 2, 2007 at 1:52 PM
The single module engine controller is located on the center of the firewall above the engine. You got it.
Dec 2, 2007 at 8:25 PM
  • 55,224 POSTS
Voltage regulator is internal to the PCM. For testing see Charging System/Testing and Inspection, here is the location of the PCM. The engine controller is located at the center of the firewall, above the engine. Check out the images (below). Let us know if you need anything else.
Jun 25, 2024 at 8:50 AM
