1990 Other Dodge Models oil pressure dropping out
1990 DODGE
150,000 MILES • V8 • 4WD • AUTOMATIC
DK012377
  • 20 POSTS
Dodge RamCharger. When we first got this truck about 6 months ago the oil pressure was sprodaic and would drop down to nothing. Upon checking and changing the oil we found that it had almost 10 qts in it. Changing the oil fixed the problem of the pressure. Recently the oil pressure started dropping out to nothing again. We have not needed to add any oil so we know there is not too much of it again, however when oil was checked it smells like there is fuel in it. Any idea what could cause this? Also it stalls every once in awhile, and has done this since we got it. We were told that the fuel pump was changed about 4-6 months before we bought it.
Jan 29, 2008 at 10:39 AM
MASTERTECHTIM
  • 4,750 POSTS
if your oil pressure drops to nothing and the engine does not make any loud noises your problem is probably the oil pressure sending unit.
Jan 29, 2008 at 10:46 AM
DK012377
  • 20 POSTS
Do you think that could cause fuel to be in the oil also? Or would you think that is a whole diff problem?
Jan 31, 2008 at 6:23 AM
MASTERTECHTIM
  • 4,750 POSTS
thats a different problem
Jan 31, 2008 at 8:13 AM
