1990 Other Dodge Models alternator
1990 DODGE
100,000 MILES • V8 • 4WD • AUTOMATIC
MIKEPEN
i have a 1990 dodge 4x4 power ram ive replaced the alternator but the system is still not charging. with the truck running i am getting interminante voltage. while truck running i will get 14 volts one time the next 12 or below. i was told the battery was good. there must be something else failing. this alternator has an internal regulator. is there a pcm that controls the charging system? running out of idea's please help
Oct 18, 2010 at 9:34 PM
HMAC300
  • 48,601 POSTS
the only thing that controls it is internal regulator on the alternator. On the 3way connection on the generator here is a black wire if you follow it back there is a fusible link on it. it may be making contact then not as it may be connected by one or two strands. it will be a smaller wire connected to a larger one or a fuse.. do not confuse the black ground wire with this one as there is a black ground wire as well or should be that contacts the alternator.... Also check yoru connections on the alternator as a wire that has only a couple of strand connection will do this as well...
Oct 24, 2010 at 8:22 AM
