1988 Other Dodge Models Radiator
1988 DODGE
130,000 MILES • V8 • 2WD • AUTOMATIC
CLEMMERB
I will be replacing my radiator. The radiator has 2 oil cooling lines at the bottom. There were 2 fittings in the box. One end of the fitting has a hose connection and the other side is threaded.
My question is should i use teflon tape on the threads or something else.
Barry
Jan 31, 2010 at 12:08 AM
BLACKOP555
  • 10,386 POSTS
i use teflon if i am to use anything at all on the threads. it should seat and seal just fine without any sealing compound but teflon assures for easier removal in the future.
Jan 31, 2010 at 5:33 AM
CLEMMERB
[quote:c675bc45b3="blackop555"]i use teflon if i am to use anything at all on the threads. it should seat and seal just fine without any sealing compound but teflon assures for easier removal in the future.[/quote:c675bc45b3]
Thank you for taking the time to answer, it was very much appreciated.
Feb 1, 2010 at 8:53 AM
BLACKOP555
  • 10,386 POSTS
no problem. good luck with your repair and if you have any questions in the future be sure to post back
Feb 3, 2010 at 10:00 AM
