1987 Other Dodge Models Re starting
1987 DODGE
90,000 MILES • 4 CYL • 4WD • MANUAL
FRANK MORRISON
Hello my car was runnunig intermittedly would drive fine then stall wait a while then will restart now it will not start cranks over then kicks back broke two starters when you push start it will run fine for a while any ideas where to look ??
Feb 25, 2008 at 1:07 PM
  • 110,251 POSTS
The kick back is usually the result of timing being set too early. Check the distributor and make sure it isn't loose.
Let me know what you find.
Mar 14, 2009 at 11:34 AM
