1986 Other Dodge Models ignition timing
1986 DODGE
DOE2VIXEN1
Engine Performance problem
1986 Other Dodge Models 4 cyl Front Wheel Drive Automatic
I need to know the exact procedure for setting the ignition timing on a 600es efi turbo . I already know that it should be 12 deg btc @ 800 rpms. How do I disable the computer advance? Or something all together different.
Jul 16, 2008 at 4:44 AM
  • 110,244 POSTS
At 800 RPM's, there is very little (if any) advance. Just turn the distributor until you reach 12 Degrees BTDC.
Mar 20, 2009 at 9:59 AM
