1985 Other Dodge Models Stopped and Won't Start
1985 DODGE
95,000 MILES • V8 • 2WD • AUTOMATIC
DARYLL4
Operating vehicle and without warning engine stopped, windows won't roll up, signals will not operate, radio will not work; battery good (checked with voltmeter); fuses good, headlights work.
Morning before this happened, left front high beam surged and blew out -- could this be associated? Voltage regulator?
What could cause this? Ignition switch maybe? Replaced ECU; waiting to replace EGR delay modules (60 sec. & 90 sec.) Any ideas?
Jun 5, 2008 at 7:22 AM
MERLIN2021
  • 17,250 POSTS
Sounds more like a battery cable problem or main fuse...Remove and clean BOTH cables remove negative first and replace it last! Check that negative at the block ground as well!
Jun 5, 2008 at 7:28 AM
