1985 Other Dodge Models starting
1985 DODGE
138,000 MILES • V8 • 2WD • AUTOMATIC
DMCCOY87
my engine is trying to turn over but it won't fully turn over. I have tried adjusting fuel flow. also the msd ignition cuts off randomly while i am trying to start the vehicle. it's backfiring and i thought maybe i could adjust the timing off the ignition but i am not sure how to do it. if someone could please shed some light to this i would appreciate it. the motor is a 440 on a dodge 150
Jun 5, 2010 at 7:34 PM
Check if you're constantly getting spark and the fuel pressure if its within specs.
Jun 5, 2010 at 7:44 PM
DMCCOY87
Yeah already tested all that out and it went just fine
Jun 5, 2010 at 8:44 PM
What you need now is to verify if the valve and ignition timing is correct-Its takes 3 things for an engine to start that is compression, fuel and spark-you got 2 of them
Jun 5, 2010 at 10:09 PM
