Hello -
Thanks for getting back with me.
I have attached the directions for you.
You will need two special tools to do this..........
The C-3564-A is used to separate the upper and lower ball joint studs.
The C-3561 is a socket to unscrew the joint.
UPPER BALL JOINT
Removal
Raise and support vehicle under outer end of lower control arm.
Remove wheel and tire.
Remove upper ball joint nuts.
Using ball joint breaker tool (C-3564-A ), free upper ball joint.
Using tool C-3561 , unscrew ball joint from control arm.
Installation
To install, reverse removal procedure, and torque all nuts and bolts to specifications.
Mar 5, 2009 at 2:16 PM
