1978 Other Dodge Models Will turn over fine, won't start
1978 DODGE
168,000 MILES • V8 • 4WD • AUTOMATIC
LEWERKE1
I've replaced the coil, the ECU, starter relay, I've set the air gap in the distributor, still won't fire at all. It's getting plenty of gas. I removed the coil wire from the distributor and held it close to the block to check for spark, but when my wife turns the key, there is only a small initial spark, and then another single spark when she releases thye ignition. While turning over, there is no spark in between...HELP!!
Apr 19, 2008 at 4:59 AM
  • 110,246 POSTS
Hi:
did you check the pick up coil in the distributor?
Mar 14, 2009 at 11:25 AM
