1978 Other Dodge Models chasis electrical problems
1978 DODGE
GUARDDAWG2021
Electrical problem
1978 Other Dodge Models V8 Two Wheel Drive Automatic
recently picked up a 78 dodge monaco motorhome thats having a few issues. I can not get the overhead running lights to work at all. headlights work fine as do the passenger tail lights and turn signal... drivers side is another story- brake lights seems to be fine, but turn signals are very dim and its all 3 lights on. when ya turn the head lights on, they tend to be a bit btrighter but not much; also they wont blink when turning unless the headlights are on. I have found only 1 fuse box sitting right next to the glove box and all fuses are good as well as the 2 in-line fuses i've been able to locate. need help
Jul 15, 2009 at 7:06 PM
HMAC300
  • 48,601 POSTS
if this is a fiberglas motor home your grounds are probably bad. YOu should have a ground wire going to the top lights and see if it is broken or one of the power wires are broken. It sounds like that seems to be your problem you'll just have to find them and fix them....
Oct 8, 2009 at 7:17 AM
