1971 Other Dodge Models iDle
1971 DODGE
DUCKLESS
Engine Performance problem
1971 Other Dodge Models V8 Two Wheel Drive Automatic
I have a crate 360 bored to 402 Magnum @ problems
I have an 800cfm eldebrock with a mopar Intake at idle it has quite qa lope to it but the problem is that if you let it sit and idle after a few minutes it will stall and then backfire and a a little rough to start afterwards.
Runs great under load but Idle is terrible also it will overheat if it sits and idles to long like at a long light and it wants to stall so some times I have to two foot it....any ideas??
Sep 3, 2008 at 10:31 AM
  • 75,988 POSTS
Check the fuel pressure if its within specs-try re-adjusting the air/fuel mix, check the PCV valve, look for vacuum leaks, wrong sparkplug heat range, choke plate not opening. also check the thermostat and fan clutch operation.
Sep 3, 2008 at 10:46 AM
