1968 Other Dodge Models idle
1968 DODGE
29,600 MILES • 6 CYL • 2WD • AUTOMATIC
MR2BERRY
car will crank and run as long as u hold gas down u don't have to hold it to the floor but u have to hold it
put new wires plugs points condenser cap. only thing i have not changed is coil
Jun 22, 2008 at 4:14 AM
DOCFIXIT
  • 18,828 POSTS
Pull off air cleaner look down into carb look to see is there visible gas coming into the venturi? Also check for vaccum leaks get carb cleaner spray around intake if it perks up ther is the leak. Set idle screw to 750 rpm.
Let me know
Jun 28, 2008 at 3:36 AM
