1965 Other Dodge Models car running rough
1965 DODGE
20,000 MILES • V8 • 2WD • AUTOMATIC
TREZOSS
The car is a 1965 Dodge Coronet. It has a rebuit 361 that is .30 over with a little cam. It runs smooth at idle, and doesnt die. When slowly pressing the gas everything is fine, but when under a load it seems to sputter pop and then take off. It has had the plugs, wires, fuel pump, fuel filter replaced not long ago. Is it the carb (edelbrock 600 cfm) or maybe the timing. Im stummped so any help would be useful.
Oct 22, 2008 at 2:14 PM
DOCFIXIT
  • 18,828 POSTS
Are you using a points dist? Did this start after rebuild?
Oct 23, 2008 at 7:37 AM
