1987 Dodge Omni oil filter
1987 DODGE OMNI
THADDEUS WASHINGTON
Engine Mechanical problem
1987 Dodge Omni 4 cyl Two Wheel Drive Automatic ? miles
the car stopped cause it was low on oil put some and changed the oil filter then when i started it oil was shooting out of the oil filter.why?
Jan 10, 2009 at 1:06 AM
  • 110,244 POSTS
Hi:
Chances are the old o-ring from the old filter stuck to the engine and the new one was unable to seal as a result. Remove the filter and check for the old one. If it is there, remove it, make sure the new one is in place on the new filter and has a thin film of oil on it and replace it.
Let me know if this helps.
Mar 5, 2009 at 11:44 AM
