1983 Dodge Omni fuel filter
1983 DODGE OMNI
CANANDAGUY
  • 6 POSTS
Engine Performance problem
1983 Dodge Omni 4 cyl Front Wheel Drive Automatic
where is the fuel filter on a 1983 dodge omni 2.2 liter I bought an old car for around the farm and i found 1 added on fuel filter but i cant find the main fuel filter. when driving the car quits and then restarts. seem to run fine but every now and then it quits.
May 4, 2008 at 1:14 PM
SERVICE WRITER
  • 9,123 POSTS
If it is carbureted, there is usually a filter that is in the carb. Remove the fuel supply line to it, and it should be right there.
May 5, 2008 at 9:44 AM
CANANDAGUY
  • 6 POSTS
[quote:ce9cef8fc0="Service Writer"]If it is carbureted, there is usually a filter that is in the carb. Remove the fuel supply line to it, and it should be right there.[/quote:ce9cef8fc0]the filter they gave me has 3 openings
May 5, 2008 at 4:06 PM
CANANDAGUY
  • 6 POSTS
[quote:87031c5450="Service Writer"]If it is carbureted, there is usually a filter that is in the carb. Remove the fuel supply line to it, and it should be right there.[/quote:87031c5450]ty for your help . I changed spark plugs and cleaned up distributor and fuel filter is fine. The car still stalls. seems to work good when first started but when i run it for a while it quits then restarts after a couple minutes. Is there an electronic spark control box on it? or any other suggestions? once when it quit i poured a little gas down the carburetor but that did not help it still didnt fire ,only after letting it cool down it started again.
May 11, 2008 at 1:22 AM
