2008 Dodge Nitro Battery
2008 DODGE NITRO
TMW121657
Electrical problem
2008 Dodge Nitro 6 cyl Two Wheel Drive Automatic
Tried to charge battery, however, the front and back lights started to flicker and the relay box was making a noise like the starter was engaged. Ground was tested and did the same thing. Is it the battery or a bad relay?
Oct 5, 2009 at 4:32 AM
  • 110,241 POSTS
You should disconnect the battery when charging. Did you try that?
Nov 8, 2010 at 4:03 AM
